Activity Forums Apple Final Cut Pro Legacy Uncompressed 8-bit quicktime from windows?
  • Uncompressed 8-bit quicktime from windows?
    Posted by Steve Lim on March 8, 2007 at 6:36 am
    Hi all,
    I work in a school where we use FCP to edit our animation footage. So far, we have been saving our clips as quicktime files using the compression – ‘NONE’. I understand that there are other ‘uncompressed’ quicktime settings that can also be used. ‘NONE’ seems to be _huge_ and unnecessary. FCP seems to like the ‘Uncompressed 8-bit 4:2:2’ setting from quicktime. It seems to be about 66% of the NONE compression filesize wise.
    However.. I cannot for the life of me find the Uncompressed 8-bit setting when trying to export from windows machines.
    Whats the catch?
    Steve.
    John Pale replied 19 years, 6 months ago 3 Members · 2 Replies
  • David Roth weiss
    March 8, 2007 at 7:22 am
    Steve,
    Install the Decklink Blackmagic codecs on you Windows machine. They don’t require a Blackmagic card and the 8-bit uncompressed codec is identical to the Apple 8-bit codec.
    Good luck,
    DRW
  • John Pale
    March 9, 2007 at 5:44 am
    AJA also has one available. Once again, identical to Apple 8 and 10 bit codecs.
    Apple only makes them available with an FCP install…not possible on a PC, but the AJA and BM codecs will work for you.
    https://www.aja.com/ajashare/AJASoftwareCodec111Setup.exe
