Activity Forums Adobe After Effects uncompressed 10bit RGB in after effects
  • uncompressed 10bit RGB in after effects
    Posted by Ignacio Chaneton on January 11, 2011 at 1:15 pm
    Hi every body.
    I’m new on the forum.
    I’m having some problems rendering uncompressed 10bit material in my after effects cs5. I’m working with a tiff seq and when I try to export it in uncopressed 10bit YUV, the colors of my movie are shifted. The original material, so far I know, is in RGB color space.
    I can’t find the uncompressed 10bit RGB option in my AE. Does anybody know if it does exist? Maybe a plugin?
    Thanks very much.
    Ignacio
    Ignacio Chaneton replied 15 years, 7 months ago 2 Members · 6 Replies
  • Joey Foreman
    January 11, 2011 at 3:38 pm
    Is your project set to 16 or 32 bits per channel?
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Ignacio Chaneton
    January 11, 2011 at 4:06 pm
    My project is set in 16 bit per channel.
  • Joey Foreman
    January 11, 2011 at 5:15 pm
    Are the colors shifted in the Quicktime player, your NLE, and/or when you re-import the rendered file into AE?
    Are you using any kind of Color Management?
    Joey Foreman
  • Ignacio Chaneton
    January 11, 2011 at 8:44 pm
    I have made some tests. I rendered the same fragment of video from After Effects in three different ways.
    – Apple ProRes HQ
    – Uncompress 10 bit YUV (preserving RGB)
    – Uncompress 10 bit YUV (without preserving RGB)
    When I reimport them to the AE cs5 I see no difference with the originals in AE, and no difference between them.
    When I open them in quicktime player 10.0 I see the apple pro res HQ a little brighter than the original in the AE Viewer, and both Uncompressed 10 bit YUV (preserving and not preserving RGB) quite darker.
    Now I’m completely lost.
  • Joey Foreman
    January 11, 2011 at 9:24 pm
    Don’t use Quicktime X. It’s not ready for prime time. Use Quicktime 7 (should be in your utilities folder).
    In Quicktime Preferences, be sure the last option, Enable Final Cut Studio Compatibility, is checked.
    You should be good.
    Joey Foreman
  • Ignacio Chaneton
    January 12, 2011 at 10:06 pm
    I tried QT 7. I still see a difference, but it is not as evident as in QT X. What relieves me now is that I see no difference between AE and Final Cut, so I can make a master from the later with out any color shifts.
    Thanks a lot
    Ignacio
