Activity › Forums › Apple Final Cut Pro Legacy › Uncompressed 10-bit D-Beta from a FW800 drive-should I trust this?
  • Uncompressed 10-bit D-Beta from a FW800 drive-should I trust this?
    Posted by Beelaster on July 5, 2005 at 7:45 pm
    I onlined my show using Uncompressed 10-bit SD to my LaCie FW 800 drive stack and all seems to be well. I thought this wasn’t supposed to work due to FW throughput, etc.
    I am a newb and I wonder whether I should celebrate or be cautiously optimistic.
    Has this situation worked for anyone else?
    Thanks for your replies!
    B
    G5 dual 2.0/5.5gig/sonnet allegro FW800 PCI/3X250 LaCie FW800 extreme/AJA Io/Horita BSG-50/DSR-45/DSR-11/M-Audio Delta 1010LT/JVC Hi-Res Ref Monitor/stock Radeon video card/Prod Suite/Logic 7.1
    Beelaster replied 21 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Beelaster
    July 5, 2005 at 7:55 pm
    Um..I spoke a little soon- the Motion menu on the Viewer is not usable right now.
  • Walter Biscardi
    July 5, 2005 at 8:01 pm
    10bit capture works fine on LaCie, but you will only have a single stream of video and your performance will definitely be a bit slow.
    If your work will consist primarily of 10bit, you’ll want something faster like a Fibre Channel array. I run my 10bit material primarily on my Medea FCR2X 2TB array.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Beelaster
    July 5, 2005 at 9:04 pm
    Thanks Walter-
    You are right about one stream-I’m finding that anywhere I want to crossfade I have to be really careful about length..It’s like nip and tuck central…I hope an audio mixdown will ease the pressure (right now I’m using 10 tracks audio/3 tracks video)
    I would love a Fibre Channel setup. Maybe I’ll get my wings after this gig. =)
    FWIW, I tried Automatic Duck-ing my show onto a Media Composer and ended up ending the session and bringing my G5/Aja to the Post House to online directly using their D-Beta deck. Things went just fine.
    I think this makes me an official FCP convert.
    Thanks for your help!
  • Beelaster
    July 5, 2005 at 10:30 pm
    The time remap settings are not working on this time line and I wonder whether that is a result of it’s 10bit setting…
  • Beelaster
    July 5, 2005 at 10:46 pm
  • Mitch Ives
    July 6, 2005 at 3:21 pm
    I think you’re pushing it. I’ve seen 8-bit work with that, but I guess we should define what working is. I don’t consider a single stream as “working”.
    What does work quite well is a four drive SATA raid which is cheap and more desirable in our minds than SCSI. We get several tracks of RT with the four drive version…
    FWIW, we’ve seen dropped frames without FCP reporting this using a single FW drive trying to 10 bit.
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    http://www.insightproductions.com
  • Beelaster
    July 12, 2005 at 3:59 pm
    Mitch-
    Thanks for writing back- As it turns out, I felt like we were too much in the danger zone for comfort. You are right- 10-bit will play, but as soon as you apply a transition, the beauty is over. It’s ok. I had my doubts, but had to try it to be sure.
    I so want a SATA array. It is the very next thing on the list. When the time came to online, we ended up bringing our rig to the post house because Automatic Duck to AVID disappointed and they didn’t have FCPHD yet. So. How much fun to see our little monster driving the $40K decks effortlessly. Such a tease.
    In the end, we laid off an 8bit DVCAM Master for Fest Apps and all is well. The film looks great and we have a little window to update things.
    Um… the long response to yr concise post.
    Bee
