Activity › Forums › Apple Final Cut Pro Legacy › Uncompress a .m2v file ?
  • Martial Bachoffner
    July 11, 2005 at 11:09 pm
    The only thing you can do is a demux to separate the video file from the audio file.
    Make a search on google with the word demux, you will find some software. You can also find one in http://www.versiontracker.com
    Regards,
    Martial
  • Andrew Yoole
    July 12, 2005 at 12:37 am
    I don’t think demuxing is the issue here. You can use Quicktime Pro (with the MPEG2 Playback component installed) to load an m2v file, then export it to any form of Quicktime file. Of course, you won’t regain the quality/information lost during the compression to MPEG2.
  • Matt Sandström
    July 12, 2005 at 7:49 am
    ffmpegx is a good free (shareware) tool. the qt mpeg-2 playback component works too.
    /matt
    https://www.mattias.nu/
