Activity Forums Apple Final Cut Pro Legacy Uncollapse “Send to Motion Project” clips
  • Uncollapse “Send to Motion Project” clips
    Posted by Dustin Bowser on July 13, 2010 at 11:03 pm
    I apologize if this topic has already been covered somewhere else, but I searched and couldn’t quite find anything. I know that In the FCP timeline you can select multiple clips, even across multiple tracks, and send them all to a Motion Project — I was wondering if there is a way to get those clips BACK if, say for instance, you want to go back to the way that it was. Basically, un-nesting those clips from their flattened state as a .motn clip. Is this possible? Does that make any sense?
    Jeremy Garchow replied 16 years, 2 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    July 13, 2010 at 11:09 pm
    Sure. When you send to Motion, there’s a timeline that is created with your original clips.
    If I use send to Motion, I always uncheck the ’embed motion content’ box and work in motion that way. I then render out a movie in Motion and import that to my timeline. If i ever need to go back to the motion project, I simply open the motion project that I saved while I was in motion after the ‘send to’ command.
    I find it easier to work that way and there’s less hiccups. Motion project can take an stupid long time to render in FCP.
    Jeremy
  • Adam Smith
    July 14, 2010 at 1:59 am
    [Jeremy Garchow] “Motion project can take an stupid long time to render in FCP.”
    Really? My experience seems quite the opposite… I often have Motion projects render several times faster in FCP. Motion only seems to use one of my eight processors, while FCP will slam them all up to 95%.
    The only downside I can see so far is the horrible motion blur in FCP… so if I need motion blur I’m stuck outputting from Motion.
    Video Photographer / Avid & Final Cut Editor
  • Jeremy Garchow
    July 14, 2010 at 6:16 am
    [Adam Smith] “Really? My experience seems quite the opposite… I often have Motion projects render several times faster in FCP. Motion only seems to use one of my eight processors, while FCP will slam them all up to 95%. “
    Yeah, that’s what I found, plus, I just prefer the workflow, even if it means an import back to FCP. I find it to be more stable, but maybe that’s just me. Glad it’s working for you! 🙂
    [Adam Smith] “The only downside I can see so far is the horrible motion blur in FCP… so if I need motion blur I’m stuck outputting from Motion. “
    Very true, how can that really be called motion blur in FCP?
