Activity › Forums › AJA Video Systems › Unable to upconvert SD to HD
  • Unable to upconvert SD to HD
    Posted by Bret Hampton on April 1, 2012 at 11:26 pm
    Hi all
    Really need your help. I’m trying to up convert some standard def footage to 1080 29.97 with My LHe card. I have tried every combination I can think of on both Mac and PC (w CS5) and no matter what I do, it won’t upconvert. The downcovert icons show up and work just fine, but whether I try analog or digital inputs, use the 720×486 SD as the primary or secondary format, nothing works.
    Since this is happening on both computers, I’m hoping I just am missing something.
    Thanks guys
    Bret Hampton replied 14 years, 6 months ago 2 Members · 2 Replies
  • Petros Kolyvas
    April 2, 2012 at 1:59 am
    I beleive one of the LHe’s limitations (the LHe Plus as well as indicated here: https://www.aja.com/products/kona/kona_comparison.php) is that it can’t upconvert in hardware. You’ll have to use software to do so (IE capture SD and then render to HD via Media Encoder.)
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Bret Hampton
    April 2, 2012 at 2:06 am
    Petros
    Thanks so much. I was driving myself crazy with this and if I’d looked at the comparison you sent would see it’s not possible.
    Appreciate that very much.
    Bret
