Unable to turn tracking data used for stabilize into usable transform
I recently tracked some footage using tracking points and was able to stabilize it. But this was simply so I could add effects and now I want to re-apply the camera shake. I tried loading the tracking data back up in the tracker panel and changing the track type to “transform” and then applying that to a null which I planned to then parent everything to. Applying the data to the null on X and Y doesn’t give the null any position data.
I’ve found that it seems I must re-track the entire scene with the “transform” track type and THEN apply this to the null and I get position data. This seems very unnecessary since the tracker point data isn’t any different. Am I doing something wrong?
