Activity Forums Adobe After Effects unable to stabilize GoPro footage
  • unable to stabilize GoPro footage
    Posted by Jon Iverson on December 16, 2015 at 5:02 pm
    I have a 15 min, 1080p GoPro video I took recently of some hiking to certain areas. The problem is that there is a lot of shaking and I was trying to use the Warp Stabilizer VFX to deshake. The problem is that I keep running out of memory, and rescaling is 150%. Obviously, this isn’t working too well and I would appreciate some suggestions as to how to proceed.
    Jon
    Jon Iverson replied 10 years, 8 months ago 2 Members · 2 Replies
  • Ivan Myles
    December 16, 2015 at 7:30 pm
    Try the stabilization function in the Motion Tracker. Be prepared to use several tracking points in series because 15 minutes is a very long duration. If the stabilized image goes too far out of frame you can adjust the Position values for the clip.
  • Jon Iverson
    December 17, 2015 at 8:18 pm
    Thanks, Ivan, but for now I’ve switched to Virtualdub and deshaker plug-in. This was something I used several years back and had nearly forgotten about it until I started having “out of memory” trouble with this footage and AE. Virtualdub doesn’t seem to have the same issues, although it is creating a huge nearly 200 GB AVI that I will have to compress in either AE or Vegas.
