Activity Forums Apple Final Cut Pro Legacy Unable to send clip to Shake
  • Unable to send clip to Shake
    Posted by Jase Tanner on April 14, 2007 at 4:26 pm
    I confess to double posting this. Its in the Shake forum but having delved a little deeper into the problem, I think perhaps the issue is one with FCP rather than Shake. Apologies if this isn’t a good enough reason.
    When I try to send a clip from FCP to Shake, I get the message “Unable to find Final Cut Pro Help folder”
    I’ve tried a safe boot, trashing FCP preferences and repairing permissions.
    The issue doesn’t arise when I try to send a clip from another project. Doing a “save as” on the problem project doesn’t help either. There doesn’t seem to be an issue with sending to Sound Track Pro
    Thanks for any help.
    Rafael Amador replied 19 years, 5 months ago 2 Members · 1 Reply
  • Rafael Amador
    April 14, 2007 at 5:30 pm
    Hi Jordan,
    Have a look in your main LIbrary>Recipts. You should have a Final Cut Pro Help package.
    If you don’t have it I would recommend you to reinstall your last version of FC because that package belong to FC. I recommend you to reinstall as well the last ProApp Support and the Apple Qmaster.
    Cheers,
    Rafael
