Activity Forums Blackmagic Design Unable to select “drop frame” when blacking a tape in “Edit to Tape”
  • Unable to select “drop frame” when blacking a tape in “Edit to Tape”
    Posted by Ryan Stegman on January 21, 2010 at 10:08 pm
    I’m having a problem blacking a tape with drop-frame time code. I launch “Edit to Tape” and I have a tape in the deck (the problem occurs in both my AJ-HD1400 DVCProHD deck and my Sony PVW-2800 Beta deck). When I press the “black tape” icon at the top of the “Edit to Tape” window, a box appears and says, “Black and Code — Settings.” I hit “OK” and the next box is where you input the starting TC. However, the check box to the right, which you select for drop-frame time code, is grayed out and not selectable.
    I am running FCP7, with Blackmagic Design DeckLink 6.8.3 running. The strange thing is, I ran a dub a week ago and I was able to select drop frame when I blacked the tape. For full disclosure, I was running Blackmagic Design DeckLink 7.3.2, but I had a problem with spitting out a down-convert signal, which is necessary for the weekly project we have. However, I don’t believe that this downgrade is the issue, because our 2 other edit suites are currently running Blackmagic Design DeckLink 7.3.2 and FCP7 (no downgrade) and they also cannot select drop-frame when doing an “Edit to Tape”.
    Is this a problem with FCP7? Did a final cut setting get corrupted?
    Any and all help/input is appreciated!! Thanks!!
    Ryan Stegman replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
