Activity › Forums › Apple Final Cut Pro Legacy › Unable to see canvass due to white square
  • Unable to see canvass due to white square
    Posted by Lawrence Eaton on August 2, 2011 at 2:45 pm
    Is there a setting that I’ve accidentally turned on (or off) so that all I see in my canvass is a white square or oblong after I hit the spacebar to stop? It’s making editing a right royal pain in the posterior and I’m not sure if it’s me or something else but I’m hoping that someone else may have come across this.
    Some stats:
    FCP 7
    MacPro – ooddles of drive space, more RAM than the continent of Africa
    Anything else, please ask.
    Many thanks,
    Lawrence
    Lawrence Eaton replied 15 years, 1 month ago 1 Member · 1 Reply
  • Lawrence Eaton
    August 2, 2011 at 2:51 pm
    Thanks to Manuel F. Rugeles and the RGB option – problem solved!
    Lawrence
