Activity Forums VEGAS Pro Unable to render fully, or print to dv device..
  • Unable to render fully, or print to dv device..
    Posted by E. Lopez on October 24, 2005 at 4:26 pm
    Hello,
    I am confronting a problem with vegas 5, that I have never had before…. My 28 minute NTSC DV project is only rendering 18 minutes, in Windows avi. format, it renders fine in mpeg 2… I am also having problems printing to control device… I tried selective rendering and it does not print to tape either, it’s asking for manual control which I do not know how to do with my sony vx2100 (misplaced my remote control)…
    Please help me with this issue as soon as possible; I have a project due today and have been trying for 2 days to fix this on my own with no luck…
    Thanks so much,
    e. lopez…
    E. Lopez replied 20 years, 10 months ago 3 Members · 4 Replies
  • Donatello
    October 24, 2005 at 6:50 pm
    the 18 min ? that seems like your hard drive is formatted FAT 32 which has a 4gig max file… mpeg 2 files are smaller
    the manual control PRINT to tape ..
    if you don’t have allot of color correction and other effects you could print from TL (tools – print to DV tape- you can then set how many seconds of color bars , black etc) .. if it tells you to use manual controls – you have your camera in VCR mode .. Vegas will give you a visual 10-0 count down – somewhere around ? 6 ? 5? ( depends on how long you think it takes for your camera to go into record mode or if you added 5-10 seconds of black you can wait till zero ) you put camera into record mode ( click record/play ? depends on camera) ..BUT 1st Vegas must render the sections of your project that has transitions, effects etc = could take 5 , 10, 20 min ?? … once finished rendering it will start the count down …
  • E. Lopez
    October 24, 2005 at 8:49 pm
    hello donatello,
    thanks so much for your help… problem solved… and i made the dead-line.
    regards, e. lopez
  • Stephen Mann
    October 25, 2005 at 6:48 am
    So, what was the problem?
  • E. Lopez
    October 25, 2005 at 3:54 pm
    hello,
    what donatello explained to me gave me a broader understanding of the functions (also helped me with the 18 minute problem) and ultimately led me to check the tape… the tape had the save tab enabled, which is why i was not able to record. as soon as i switched it to record, i was able to print to tape.
    i appreciate all the help…
    thanks, e. lopez
