Activity Forums Apple Final Cut Pro Legacy unable to render
  • unable to render
    Posted by Alex Smee on June 23, 2008 at 3:57 am
    i have just moved an FCP project from a MAC with FCP 5.1.4 to a MAC with FCP 6.0.1. the new computer is running OSX 10.5.2
    the timeline contains a psd file that has a light ray effect on it. the effect worked on the original MAC, but when i try to render it on the new MAC, i get a message saying ‘unable to render light rays’. (white writing on a red background where the clip should be)
    the strange thing is that, there is one old timeline in the project, that DOES play back the effect. i think maybe this is because it is reading an old render file, because when i copy and paste the psd with the ray effect into the new timeline, it will not play back.
    both old and new versions of FCP have the light ray effect, so not sure why this is not translating?
    thanks for help.
    alex
    Jerry Hofmann replied 18 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 23, 2008 at 1:11 pm
    I’m unclear why it won’t render, but if you have a sequence with it rendered in it, you should be able to export a self contained movie file of it, then just cut that into your sequence.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
