Activity Forums Adobe Premiere Pro Unable to pull both audio and video from source window
  • Unable to pull both audio and video from source window
    Posted by Lisa Hurley on August 6, 2010 at 6:19 pm
    Hello All!
    I’m having the weirdest thing happen in Premier CS4. When I try to drag and drop a clip into the Timeline from the Source Window, only the video comes. I see the option below the source window to pull ONLY the video, but I’m wanting to pull both. I’m placing my mouse in the source window, and dragging directly into the timeline… I only get video. Now, when I right click on the source window, and select “Insert”, I get both audio and video.
    Does anyone have any idea why dragging from the source window won’t bring my audio with the video?
    Lisa
    Simon Bonner replied 16 years ago 2 Members · 1 Reply
  • Simon Bonner
    August 27, 2010 at 5:28 am
    The only time something like this has happened to me is when my Prem window is too small and I can’t see that the audio is mono and therefore doesn’t show up on the top few audio tracks, which are stereo by default (usually a new mono track is created at the bottom of the stack). I’m sure you would have noticed if this was the case, but as you’ve had no replies…
    Simon Bonner
    youtube.com/simonsaysfx
