Activity Forums Adobe Premiere Pro unable to play back entire rendered sequence
  • unable to play back entire rendered sequence
    Posted by Zach Gold on March 13, 2011 at 2:47 am
    Continuing my transition from FCP to Premiere, I’m having an odd issue with a project. I cut up a clip with the razor blade tool, copied it a few times, reversed some in the speed/duration panel and arranged them in a sequence. I then rendered the entire work area. However, when I try to play back my sequence, it just plays less than a second and then the marker on the timeline returns to the original point. I feel stupid asking this, but…uh, how do I just play back my entire sequence? I must be missing something here.
    Zach
    Valentino Laz replied 13 years, 2 months ago 4 Members · 10 Replies
  • 10 Replies
  • Vince Becquiot
    March 13, 2011 at 10:04 pm
    Hi Zach,
    Something is obviously not working right. The first thing to look at are plugins in your clip. Try removing them and see if things improve.
    Also check for the latest display drivers. Check that you have the latest Premiere update. Also, remove any antivirus, malware software, they are well known to conflict with editing systems.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jon Barrie
    March 14, 2011 at 4:13 am
    Is it possible you have set in and out points on the sequence and have the loop function the the program monitor? It will only play back in the in out section when you hit play with the loop on. Clear the in out points. Shortcut is “g” key.
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Zach Gold
    March 14, 2011 at 11:09 pm
    There are no in or out points on the sequence and the loop function is off. It almost appears similar to a RAM preview in After Effects…
  • Jon Barrie
    March 14, 2011 at 11:15 pm
    Can you post a screen capture image. Thanks
    Jon Barrie
    aJBprods
  • Zach Gold
    March 14, 2011 at 11:16 pm
    I don’t see what’s to gain from that. The problem is not visual. It’s time based…
  • Jon Barrie
    March 14, 2011 at 11:20 pm
    So we can see your interface.
    Jon Barrie
    aJBprods
  • Jon Barrie
    March 14, 2011 at 11:26 pm
    Jon Barrie
    aJBprods
  • Zach Gold
    March 22, 2011 at 9:52 pm
    Any ideas here? This is extremely frustrating.
    Zach
  • Zach Gold
    March 22, 2011 at 9:55 pm
    Here’s a screen capture, if you can make anything from it: https://tinypic.com/r/24oy5ox/7.
  • Valentino Laz
    June 26, 2013 at 8:35 pm
    I am having the same Issue, space bar does not work, no playing even when rendered.
