Activity › Forums › Adobe Premiere Pro › Unable to output 5.1 audio
  • Unable to output 5.1 audio
    Posted by Paul Mckinney on August 7, 2014 at 6:38 pm
    Hi
    I have a project in Premiere Pro CS 5.5 that has a 5.1-channel audio track. When I expand the track in the timeline, I can see the channels are mapped in the following order: L, R, Ls, Rs, C, LFE. I am trying to output an MP4 with 5.1 surround sound and am having difficulty.
    When I try to export, I notice in the export settings summary that the source material is listed in stereo, and not 5.1. As a result, when I try to output to a file with 5.1 settings, I get an error message that says “the source and output channels are not compatible or a conversion does not exist”.
    Perhaps I’m missing some kind of setting to make sure that my project is a 5.1 project but I can’t find it. Another odd thing is that when I right-click on the 5.1-channel audio file and click on “modify>properties”, the default mapping for the file is different than what I see in the timeline. It’s listed in the order L, C, R, Ls, Rs, LFE.
    I do have one other mono track in the timeline (as a sync reference for the 2-pop) but I have it muted upon export.
    Julian Lang replied 11 years, 6 months ago 2 Members · 2 Replies
  • Paul Mckinney
    August 7, 2014 at 7:04 pm
    I think I just answered my own question. When I initially set up the sequence, I needed to set up the MASTER audio channel as having 5.1 surround sound. The default was stereo.
  • Julian Lang
    March 7, 2015 at 5:11 pm
    I’m having the same problem. Were you able to solve your problem? I am working with sequences which have stereo, mono, and 5.1 surround audio files. I am exporting them to clean them in proTools. The surround sound files will not export in the 5.1 array–as a result I am unable to properly adjust levels, etc.
    Still plugging.
