Activity Forums Apple Final Cut Pro Legacy Unable to open project files and XML Translation was aborted due to a critical error
  • Unable to open project files and XML Translation was aborted due to a critical error
    Posted by Richard Price on April 6, 2008 at 1:12 am
    Hi Guys I’m having problems opening a FCE 3.5 project file working off a 2.4ghz Mac Book Pro. I have been working on this for a few weeks but over the last 3 days I started to get the message “Unable to open project file”. I have read on a few different sites about this subject but haven’t seen any with the specifics as my own. So apologies in advanced if you have already been over this.
    I have all the recent updates For OSX and have tried going into the Auto Vault and Render files to access the last available versions of these project files. I am able to access those but am only left with a much earlier version of the same project like a version a week earlier without vital changes.
    I have my media and rendered files all backed up on to an external Hard drive , I have tried un mounting the ext Hard drive to separate any corrupt media which may be disturbing my files to see if I can still open the project but haven’t been successful .
    I have tried backing up on time machine but would have to go to far back to reach a suitable restore point.
    The message appears when I open the file in two ways by clicking on the file from accessing my Ext Hard drive and by Launching normally from the dock FCE > File > Open
    I know it’s relatively the same method but didn’t want to over look anything.
    FCE loads up it looks as if it is going to load fully the Browser and Viewer load but none of the other windows appear then the message appears and I’m forced to press ok .
    I have had some great advice on this problem but haven’t yet been able to crack it , I have had help by sending the corrupt project files to other editors using FCE4 , FCP6 who have been able to access it on their machines.
    I have also trashed my preferences files those being :
    Com.apple.finalcutexpress.plist
    And the 3 files in the Final Cut express user data the 3.5 Prefs , Obj Cache and the Prof Cache .
    I was sent my same Corrupt file back to me in the form of as an Xml File to see if I could drag that into FCE browser but was stopped by the message
    “XML Translation was aborted due to a critical error”
    I searched online and found out about this message and after making a copy of the Xml file the next step was to try and fix the errors in the log notes. I’m not sure if this was the right way to go but I figured if I could compare a working exported FCE Xml with a broken one I could find some type of discrepancy.
    FCE 3.5 doesn’t seem to be able to export sequences as Xml as easy as my other version of Final Cut 5.04 – Which sadly cannot open the same FCE file I am having problems with .
    Is there a way to export the sequence as an Xml File from FEC 3.5.1 so I can compare ? Or a way around this problem I haven’t tried . The thought of starting from a previous version is a major downer.
    Much Appreciated , Sorry for the Long Message I just wanted to show what I have tried to do before posting for more Help
    Regards
    Richard Price replied 18 years, 5 months ago 2 Members · 2 Replies
  • Russell Lasson
    April 6, 2008 at 9:19 pm
    [Richard Price] “Is there a way to export the sequence as an Xml File from FEC 3.5.1 so I can compare ?”
    I don’t use FCE, but I don’t think that is works with XML files. FCP 5 or 6 should open it, but getting it back to FCE really isn’t an option.
    I don’t know what would be causing such an issue. You’ve already been quite complete in trying to figure out what to do.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Richard Price
    April 6, 2008 at 10:23 pm
    Thanks very much for your reply Russell , I wasnt sure if my version of Fce supported Xml files as it does’nt have a sub menu option for exporting those files.
    I am gonna keep going over the steps and see if i have missed something.
    Regards
