Activity Forums VEGAS Pro Unable to open an avi file :(
  • Unable to open an avi file :(
    Posted by Vic Santiago on July 28, 2013 at 1:05 pm
    Hello,
    I am unable to open an avi file of a movie in Vegas Pro 12 for editing.
    It’s a compressed avi file, mpeg1 video codec, 352×240 frame size, 1152 video frame bit rate, 29.97 frame rate, mp2 audio codec, 128 audio bit rate, 44.1KHz sampling rate.
    How do I determine the codecs I need to add to Vegas Pro to open avi files of these properties, and where can I download them?
    Vic Santiago replied 13 years ago 3 Members · 6 Replies
  • Pete Mack
    July 28, 2013 at 4:57 pm
  • Stephen Mann
    July 28, 2013 at 5:49 pm
    1. DO NOT install a Codec Pack made for gaming, like K-Lite. It will replace otherwise overwrite the good encoders installed by Vegas.
    2. Use MediaInfo to see what is in the AVI container.
    3. DO NOT install a Codec Pack.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Vic Santiago
    July 29, 2013 at 2:41 am
    This avi file will open in VP8 on an older Win XP 32 bit system.
    Is the problem due to the fact that I have VP12 64 bit on Win 7?
    I read this thread….
    https://www.sonycreativesoftware.com/Forums/ShowMessage.asp?Forum=4&MessageID=859053
    and Im wondering if installing the codec suggested in the thread will solve the probem…
    Thanks.
  • Pete Mack
    August 8, 2013 at 10:08 am
    delete/double post
  • Pete Mack
    August 8, 2013 at 10:10 am
    Vic,
    I recently had the same problem. When I converted
    the AVI file to an MP4 file Vegas accepted it. When
    I initially tried to put the AVI file on the timeline
    Vegas rejected it. The converter I used was the
    Pazera Free Video to iPod Converter. If that works
    let us know. And oh I’m using Vegas Pro 12 like you.
  • Vic Santiago
    August 8, 2013 at 4:17 pm
    Peter, I converted the avi file to another avi file using the default NTSC DV codec on the Any Video Converter app.
    It’s a workaround but at least the new avi file now opens up in Vegas 12.
