Activity Forums Adobe Premiere Pro Unable to open a project (located on external drive) on another system
  • Unable to open a project (located on external drive) on another system
    Posted by Johan Windh on November 5, 2014 at 2:44 pm
    I’m working on a project which is located on an external drive for mobility. On one system it works just fine. On another, the project won’t open.
    I get a Scratch Disk message, (I’m not able to change Scratch Disks to the external drive if I start a new project. It says that there is no writing access to that Drive, but there should be, I’ve checked).
    I then get the “unknown error” message, and not opening the project.
    I’ve also tried to import the project into a new one, but I then get the fantastic “general error”.
    Any clues on this?
    Kind Regards,
    Johan
    Johan Windh replied 11 years, 10 months ago 3 Members · 3 Replies
  • Chris Gunningham
    November 5, 2014 at 3:18 pm
    you could try starting a new project, set scratch disks to a local drive then import the project or sequence from the external drive using media browser.
  • Jeff Pulera
    November 5, 2014 at 9:09 pm
    Keep in mind that older versions of Premiere cannot open Projects created in newer versions.
    For example, CC can open a CS6 project, but CS6 cannot open a CC project. Not sure what versions you are running, but that might be an issue.
    Jeff Pulera
    Safe Harbor Computers
  • Johan Windh
    November 6, 2014 at 8:40 am
    Thanks guys. Both systems run CS6.
    I tried to set scratch disks to local and import through Media Browser, but I only got the “beach ball of death” and Application Not responding…
    Kind Regards,
    Johan
