Activity Forums Avid Media Composer Unable to modify Sound TC column
  • Unable to modify Sound TC column
    Posted by Alex Winker on August 30, 2017 at 12:06 am
    Hello,
    I’m having an issue populating the Sound TC column with timecode from another column, namely Aux TC 1. When I enter the timecode into the Sound TC column, I get an error that says
    Select Sound TC frames per second for clips without Sound TC.
    NOTE: Sound TC frames per second can only be changed by clearing and re-entering Sound TC
    The dialogue box then gives these three options “30”, “24”, “Cancel”
    The frame rate of the clips and the audio are both 23.98 which is not listed as an option, and even if I press the “24” button, I get another error that reads:
    Exception: SM_DF_NDF_MISMATCH
    This issue only occurs when changing the Sound TC column for video files, there is no issue when changing the column for audio clips.
    I am desperately trying to figure out how to get these timecodes in the Sound TC column, any help is greatly appreciated.
    Thank you!
    -A frantic AE
    Michael Phillips replied 9 years ago 3 Members · 3 Replies
  • Michael Phillips
    August 30, 2017 at 1:48 am
    24 is the correct selection. Even though the play rate is 23.976, the timecode still counts as 24. Now as to why that happens is the issue. Do the video clips have at least an A1 track associated with it?
    Michael
  • Job Ter burg
    August 31, 2017 at 9:28 am
    Have you specified SoundRoll as well? I don’t think you can get Sound TC without SoundRoll.
  • Michael Phillips
    September 2, 2017 at 1:48 pm
    I wish these limitations of Soundroll and A1 track didn’t exist. Haven’t done enough testing to see which ones if either is still needed but they were at one time. The whole design of Soundroll and SOundTC on a Master clip of V only or VA is to reference the double system sound used for EDL or possible syncing operations. I never understood why the dependence of an A track and another field had to exist.
    Michael
