Activity › Forums › Adobe Premiere Pro › Unable to merge clips in CS6 synced using PluralEyes
  • Unable to merge clips in CS6 synced using PluralEyes
    Posted by Andrew Moir on December 23, 2014 at 8:59 pm
    I’m new to both CS6 and PluralEyes 3.5. Whenever I try to merge clips in CS6 that I synced using PluralEyes I receive this error message:
    Premiere Pro has experienced an error [/Volumes/BuildDisk/builds/mightykilt/shared/adobe/MediaCore/Backend/Make/Mac/../../Src/Clip/AudioClip.cpp-791]
    I have been importing the media files directly into PluralEyes (the CS6 extension manager for PluralEyes doesn’t work for me either), syncing the footage, then exporting the synced footage as an XML. I am able to import the XML media into CS6 perfectly fine but the problem occurs as soon as I try to merge the audio/video together.
    Thanks in advance for any guidance.
    Andrew Moir replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
