“Unable to locate timecode” error on batch capture??
I am tying to capture HDV/24P material in Final Cut using the Sony M35U deck and continue getting the above error for about 25% of clips during the “Batch Capture” As a workaround I’m having to capture the problematic clips with “capture now” which captures the same time-codes flawlessly every time without a problem? This leads me to believe there is not actually a timecocde problem but something is going wrong between Final Cut’s communication with deck?
I have tried all the recommendations I am reading online:
-change pre & post roll settings
-unchecking “abort capture on dropped frames”The error persists, I’m stumped? Any hints are much appreciated.
