Activity Forums Blackmagic Design unable to locate external device?
  • unable to locate external device?
    Posted by Zach Bauer on February 12, 2007 at 3:24 pm
    I’ve been having problems with my Blackmagic card lately. So i uninstalled and reinstalled the software and I did the same with Final Cut Pro to be safe. And when I open up Final Cut it lets me select the black magic setting and then says it is unable to locate the external device “Blackmagic HDTV etc.” Any ideas what i could do? thanks
    Zach Bauer replied 19 years, 6 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 13, 2007 at 5:46 am
    Is the card showing up in System Profile?
    Are you able to toggle the options in the DeckLink Preferences?
    In Final Cut Pro, open Audio/Video Settings, click on the Capture Presets Editor, edit the current present you’re on and check if the digitizer is set up correctly.
    regards
    Kristian Lam
    Blackmagic Design
  • Zach Bauer
    February 13, 2007 at 3:34 pm
    The card is on my system preferences, but everything is greyed out. In Final Cut it allows me to choose the blackmagic card, but my playback output options says it’s missing. How do i check if the digitizer is set up correctly? Also when i try and run the blackmagic speed test it says that the hardware is not found. It’s in the top slot of my G5.
