Activity › Forums › Adobe After Effects › Unable to link assets to Element 3D
  • Unable to link assets to Element 3D
    Posted by Phil Lister on September 18, 2023 at 1:23 pm
    I had to re-install Element 3D, once I did, none of my assets are being seen, even though I used the correct file path. I have tried multiple times to re-install the plug-in and I even tried to re-link all assets after installing Element. What am I doing wrong? None of the assets were moved. Everything is still in the folder as before.
    Hector Vera replied 3 years ago 2 Members · 1 Reply
  • Hector Vera
    September 19, 2023 at 12:27 am
    That is rather strange, did you tried opening the project files of Elements 3D to see if you can reload all the assets you were working on previously there? Cause from my experience with Vegas and Premiere Pro, if I uninstall and reinstall, as long as the project files contains all the assets used and all are in the same location on the computer, it should be able to load.
