Activity Forums Adobe After Effects unable to invert matrix error
  • unable to invert matrix error
    Posted by Alan Parma on April 1, 2007 at 11:34 pm
    hi guys. i searched this forum for this error, and i only found two w/c said to update to 6.5.1 and a parenting issue. i’m using AE 7 and i’ve disabled parents and i still get the error. it occurs on when it tries to render a 3D precomp (layer with rasterize on, 3d layers inside, it’s a building with flat sides arranged in 3d space). there’s no error when doing a RAM preview, but when rendering out to animation QT with alpha, it always gets this error. what could be the problem? thanks.
    Steve Roberts replied 19 years, 5 months ago 2 Members · 1 Reply
  • Steve Roberts
    April 2, 2007 at 2:57 pm
    Troubleshoot:
    – switch off effects
    – try a different codec
    – try rendering to a TGA sequence
    – try rendering to a different drive or defrag the drive
    – try rendering at smaller size/lower res
    – try rendering a shorter work area
    – try rendering RGB only, and add an output module (composition>add output module) with alpha only, then use the alpha as a track matte (for the RGB) wherever you were going to use the RGB+alpha movie
    Some of those will give a render you can use, others will just give you clues. Go to it!
