Activity Forums VEGAS Pro Unable to install presets
  • Unable to install presets
    Posted by Rick Hughes on October 21, 2013 at 10:05 pm
    Installed latest Preset manager from Sony web site.
    I have 64 bit Sony Movie Studio Platinum 12
    I downloaded the preset files as explained in this video:
    https://www.youtube.com/watch?v=gC1OxbOY5pA
    Preset manager opens I point it for example to Mikes Presets (sf file) the files show in top right pane, but when I select then and choose ‘copy to system’ none of them appear in the FX Chains folder …
    Can anyone assist ?
    see pic attached:
    6659_presetgrab.jpg.zip
    Graham Bernard replied 12 years, 11 months ago 3 Members · 6 Replies
  • Steve Rhoden
    October 22, 2013 at 2:22 am
    Sorry here, I’ve never fully tried or go in-depth with
    the Presets Manager.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Graham Bernard
    October 22, 2013 at 6:06 am
    _______________________________________________________________
    [Rick Hughes] ” but when I select then and choose ‘copy to system’ none of them appear in the FX Chains folder …”
    Ah, I got it now . . The FX Chains Folder still within Preset Manager! My mistake . . got it . . ok . . . Maybe you’d need to do a reboot of your System to have them be revealed. But do you have them showing in Vegas?
    This is what I do to retrieve the Filter Packages – which consists of Linked Chains of FXs. Note that I have 2 Folders of Packages: GB and JMH.
    Either here from the Plug-In Chooser Menu Pane:-
    Or from here in the Plug-In Manager Menu Pane:-
    If this doesn’t get you there then get back to us, . . er . . here!
    NB: Bill shows how to remove each and every Chain from the Event’s CHAIN-ed FXs Filter Package. Here’s a TIP: Just drag a new Filter Package to the Chain area on your Event or JUST the Event and the new one will replace the existing CHAIN of FXs.
    Cheers
    Grazie
  • Graham Bernard
    October 22, 2013 at 6:42 am
    Rick, I’ve just re-tested by importing a NEW to me set of Presets off of the NET. The process allowed me to reveal FX Packages in the PresetManager “FX Chains” folder. I had to click on the several folder options for them to reveal – but show-up they did.
    I now have them working nicely in VP12 B726.
    Where are you getting your Presets from?
    Grazie
  • Rick Hughes
    October 22, 2013 at 9:26 am
    Tried it again after booting PC .. still the same .. they appear in top right pane of Preset Manager, but when I select and then “add to system” they should appear in bottom right pane … they don’t.
    This is following the preset manager instructions ….
    However this time I did it with Movie Studio closed …and when I booted it up the presets were there.
    Assume there is a bug in it … or maybe just does not work that well with Movie Studio 64bit
    I now have 100+ presets … sure I’ll only use a few.
    I got all of these from the 3 links in the you tube post … could be real neat way of getting some smart effects without extra filters.
    If you want a copy I’ll upload files – they are very small all 3 packs are under 0.5MB
  • Rick Hughes
    October 22, 2013 at 9:33 am
    Graham … do you use preset manager, or do you manually drag files using windows explorer.
  • Graham Bernard
    October 22, 2013 at 10:36 am
    Preset Manager
    G
