Activity › Forums › Blackmagic Design › Unable to install H.264 Pro Recorder on windows 7 – 64Bits home edition
  • Unable to install H.264 Pro Recorder on windows 7 – 64Bits home edition
    Posted by João Manuel tocha on December 6, 2011 at 5:00 pm
    Hi! I am not able to install the Pro Recorder on my laptop, after I install Desktop Video 9, i connect the usb cable from the unit and it start’s “Installing device driver software” -> searching windows update and then it gives the following message: Failed
    Any ideias? on the mac I had no problem installing the device, and everything worked has expected, it even updated the firmware of the device.
    Thanks in advance.
    João Tocha
    Roger Jennings replied 13 years, 8 months ago 3 Members · 2 Replies
  • Benjamin Gilmore
    May 8, 2012 at 8:11 am
    Hi João, I was just wondering if you found a solution to your problem? We are having the same issue on one of our studio computers at the moment…
  • Roger Jennings
    January 18, 2013 at 8:05 pm
    Hi João,
    I, too, am having this exact same problem. Did you find a solution that you can share?
    Roger
