Activity Forums VEGAS Pro Unable to install DVD Architect 5.2
  • Unable to install DVD Architect 5.2
    Posted by John Gallagher on December 11, 2012 at 11:32 am
    Hi folks, I’ve been using DVD Architect 4 for a while and wanted to upgrade to 5.2, I downloaded the trial to see if it was worth buying it or sticking with 4. However, when I click on the installer exe, the warning screen appears as usual asking if I’m sure I want to install, I click ‘run’ and then nothing happens. The installer pre loader icon appears on my taskbar as usual but it doesn’t do anything. I can’t close it either, I have to go into the task manager to end the process. There is also a strange little box that appears on the bottom right hand side of the screen with an ‘S’ on it that also doesn’t appear to do anything.
    The installer for DVD Architect 4 seems to open fine. It’s quite frustrating, so any help would be lovely.
    Cheers,
    John
    John Gallagher replied 13 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    December 11, 2012 at 4:28 pm
    Try restarting your computer before you install it.
    And Version 6 is out now, why dont you try and get
    a copy of that.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • John Gallagher
    December 11, 2012 at 8:26 pm
    Thanks for your reply. I tried restarting but that didn’t work, and I downloaded version 6 but that is doing the same thing, which is a bit disconcerting.
    Its not as if the installer preloader has stopped working or is not responding because the task manager states that the program is running but other than being on the taskbar and that strange little box it’s doing nothing.
    Thanks for your input, much appreciated 🙂
  • Steve Rhoden
    December 12, 2012 at 6:32 am
    Tell you what, completely uninstall Architect 4 and delete
    all folders in the system files and in my documents that pertain
    to DVD Architect, Restart the computer and when you are ready
    to install Architect 6, right click on it and select
    run as administrator (which is to install as administrator).
    This most likely will work now.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • John Gallagher
    December 12, 2012 at 3:25 pm
    Hi, well I did everything you said and still no luck. I even downloaded a couple of other trial programs from Sony to see if it was a problem with all the software. Acid Pro and Spectra layer seemed to be fine, but the Vegas pro suite and Sound Forge would not open.
    I’m going to do a full virus scan and see if any programs are stopping it, if I have no luck I’ll stick with version 4.
    Below is a screen capture of the small box that appears if that helps, but otherwise thanks for your efforts, I really appreciate it.
    John
  • John Gallagher
    December 14, 2012 at 8:32 am
    An update on the problem. I solved it simply by going offline and turning off my anti-virus and firewall. Not sure which one it was but I now have DVD Architect 6.
    Thanks 🙂
  • Steve Rhoden
    December 28, 2012 at 12:32 pm
    Which anti-virus is it?
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • John Gallagher
    December 28, 2012 at 3:51 pm
    Virgin Media Security. We get it free as they are our internet providers.
