Activity › Forums › Apple Final Cut Pro › Unable to “Insert Edit” in this particular Project
  • Unable to “Insert Edit” in this particular Project
    Posted by Joe Taylor on October 27, 2017 at 6:25 pm
    Hello. Having a problem with a new project where I am unable to “Insert Edit” clips into the timeline. Even the “Insert” is not highlighted in the “Edit” dropdown menu. I’m used to dragging the clip to the timeline and easily dropping it the desired part of the timeline. Any ideas what is wrong here? Using 10.3.4.
    Many thanks.
    Suan k. Seol replied 8 years, 10 months ago 5 Members · 10 Replies
  • 10 Replies
  • Scott Witthaus
    October 27, 2017 at 6:41 pm
    So when you have the project timeline active (command-2), you can’t use the W key to insert a clip? Might want to restart X and trash prefs on launch (hold option-command keys down while launching FCPX).
    Scott Witthaus
    Owner, 1708 Inc./Editorial
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
  • Joe Taylor
    October 27, 2017 at 7:09 pm
    Hello Scott,
    Tried your advice with no luck yet. One thing that is different from this timeline than the others is that there are blue dots that correspond with the head and tail of every clip that are situated just above the audio track.
    Have only been using FCPX for only a few months and sometimes it drives me nuts.
  • Noah Kadner
    October 27, 2017 at 11:42 pm
  • Joe Taylor
    October 28, 2017 at 1:42 am
    Here is a screen grab. Hopefully it loads.
    https://images.creativecow.net/49133/stelzerscreengrab.jpeg
  • Joe Taylor
    October 28, 2017 at 2:41 pm
    I searched online for possible remedy’s or hours last night with no luck. If you can guys can glean anything from the screenshot I posted I’d love to hear from you. Otherwise I’m just going to abandoned this version and start all over with a version 2.0. Kelly don’t have time for that.
    Many thanks!!
  • Matt Galuszewski
    October 28, 2017 at 9:46 pm
    Are you happy to share an FCPXML of the library?
    I obviously won’t have the media but at least I can have a look to see if I can find anything amiss.
  • Joe Taylor
    October 29, 2017 at 12:35 am
    Hello Matt, would be happy too. Let relook into how that’s done in case something like this comes up again… and it will.
    I went ahead and started the project over from scratch.
  • Matt Galuszewski
    October 29, 2017 at 12:43 am
    Was it any project in the library you had difficulty with or just one project in the library.
    If you want to, export a XML of the ‘bad library’ by selecting File > Export XML and upload it to here.
  • Joe Taylor
    October 30, 2017 at 4:03 am
    It was just a project with a single storyline. I went back and did complete rebuild of the project. It all worked out in the end. Thank you.
  • Suan k. Seol
    November 19, 2017 at 1:34 pm
    Did you check if your cursor was in ‘position’ mode instead of ‘select’?
    Yeah, you solved the problem by rebuilding the project, but just in case, next time if it happens, you could double-check it.
    I had the same problem and it was that simple problem, my arrow was in ‘position’ mode. It could be confusing as they look similar and do everything else same except for inserting clips.
