Activity › Forums › Apple Final Cut Pro Legacy › Unable to Initialize Deck
  • Unable to Initialize Deck
    Posted by Angela Zumbrum on March 14, 2013 at 7:40 pm
    Searched and read almost every post with this same Subject before posting. Having NO luck.
    Using Mac OSX 10.5
    FCP 6
    Capturing min DV from a Sony Camera ( DCR-HC42 NTSC)
    Connected with FireWire from camera to Computer
    Unable to initialize deck, you still may log offline. is this only message I am getting.
    Any help would be appreciated!
    Angela Zumbrum replied 13 years, 6 months ago 2 Members · 4 Replies
  • Steve Eisen
    March 14, 2013 at 8:15 pm
    Try using Easy Setup.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Angela Zumbrum
    March 14, 2013 at 8:48 pm
    Did that too. I typically edit HD video, and was a little taken back while trying to change all of the settings manually. What option should I chose for Easy Setup ? I’ve tried NTCS. What options should I chose? Rate? Custom Setup? Thank you.
  • Steve Eisen
    March 15, 2013 at 3:06 am
    DV NTSC is all you need. FCP does the rest.
    Steve Eisen
    Vice President
  • Angela Zumbrum
    March 15, 2013 at 1:30 pm
    Still nothing. I know that I have captured using this camera before. What the heck am I forgetting this time? Tried 2 different Firewire cables, two different ports on the Mac. I am capturing to an external hard drive, and thought that it may be causing the issue. So, just to test, I tried capturing to my internal system drive and got the same message. Unable to initialize deck. UGH!!!
