Activity › Forums › Adobe Premiere Pro › Unable to import DNG files
Posted by Jamie Milks on November 1, 2013 at 7:14 pmI open up the latest update to Premiere Pro to test out the CinemaDNG support but when I go…
File > Import > (select my folder containing my DNG files) I am unable to Import as ‘Image Sequence’. The check box remains uncheck-able.
Am I doing something wrong or missing a step here?
After I click ‘import’ it appears as its beginning to import the files then an error is generated:
“File Import Failure
Error Message
The file appears to have no media data.”Khalid Butt replied 11 years, 4 months ago 5 Members · 10 Replies -
Peter Garaway
November 1, 2013 at 9:03 pmPlease try importing the CNDG files through the Media Browser.
Best,
Peter Garaway
Adobe
Premiere Pro -
Jamie Milks
November 2, 2013 at 5:40 pmHi Peter, thanks for responding but I am getting the same error msg.
The DNG files are a simple Time Lapse taken on a 5D MIII.
I guess this isn’t supported as of yet correct?
Peter Garaway
November 2, 2013 at 8:57 pmHi Jamie,
Here’s the official statement:
Premiere Pro CC 7.1 supports Uncompressed Cinema DNG from Blackmagic Cinema Cameras. Import and edit uncompressed Cinema DNG media (or ProRes or DNxHD media) from Blackmagic Cinema Cameras. Cinema DNG can be debayered on a supported GPU for extreme playback performance.
https://www.adobe.com/products/premiere/extend.html#Supportedvideoformats
With that said you may still be able to import certain non Blackmagic CNDG files but they are not officially supported. Are focus for this release was Blackmagic Cinema DNG support and debaryed GPU accelerated.
We look forward to adding additional support for other CNDG file types in future releasees.
Add it to your wish list:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Best,
Peter Garaway
Adobe
Premiere Pro -
Alex Fuchs
January 23, 2014 at 10:23 amHi Jamie,
try to import the DNG’s over Davinci Resolve (lite version free to download, but restricted to max. 1920×1080 footage). Load them in Resolve and export them as proxies in a format you prefer. Then import the proxies in Premiere Pro, do your edit and at the end export your edit as XML and go back to DaVinci Resolve. Do your Grading there and export it in the Final master format. Should work.
Cheers,
AlexAlex Fuchs
DoP/Editor/Motion Effects
Visual BastARTS
http://www.visual-bastarts.com -
Andras Polonyi
December 11, 2014 at 11:38 pmJamie this is ridiculous. I have been a PP user since day one, and the only reason I have switched to
CC Premiere is because of it’s ability to import and edit DNG sequences. And it totally did!-until now
I had no issue to import any kind of DNG seqs. Looks like your latest upgrade is a downgrade. I’m very disappointed in Adobe. This thing actually f****d my workflow. Looks like i’m paying 25 pounds /mont for a software that just became totally useless. Great. Not feeling much for Adobe at the moment….Andrew
Peter Garaway
December 12, 2014 at 12:08 amHi Andras,
Can you please give more details about the issue your experiencing? Please also include which version of Premiere Pro you have and system specs.
Sorry your having troubles.
Best,
Peter Garaway
Adobe
Premiere Pro -
Andras Polonyi
December 12, 2014 at 12:55 amHi,
It’s Premiere Pro CC 7.2.2. And it just wouldn’t eat the DNG files. I just don’t get it. And I’m shooting RAW tomorrow. If there is no work around I’m just going to unsubscribe from my Adobe membership and do Avid or FCP. This is crazy! Especially cause it was working like a dream before. Unbelievable….
Andras Polonyi
December 12, 2014 at 1:12 amSorry,
It was my bad. I thought that I’ve updated but it wasn’t the CC 2014, it was an earlier version.
I just updated to 2014 and it works again!Thanks a lot for getting back to me!
Regards,
Andras
Peter Garaway
December 12, 2014 at 4:29 amHappy to hear all is working again.
Enjoy!
Peter Garaway
Adobe
Premiere Pro -
Khalid Butt
April 24, 2015 at 1:04 pmI think its a total confusion between DNG and CDNG ? DNG files are not Cinema DNG file. I have exactly the same problem. I have premiere CC 2014 and CS6. if i convert Raw video to DNG and later open with any premiere program it hangs or stops working. also sometimes it gives me the error that unable to load / unsupported format or damage file…..etc
On the other hand, If I convert Raw to CDNG it opens in premiere but with pink screen and cropped 3X.
I have problem in both DNG’s. neither of them seems to be working on my premiere.
Once Again I emphasize that I want to import DNG NOT CDNG in premiere. any update will be of great help.
Thanks in advance
