Activity Forums VEGAS Pro Unable to import avi into Vegas 10?! plz!
  • George Mccreadie
    April 20, 2011 at 7:20 pm
    Perfect! Nice quick convert into somthing vegas likes 😉
    One last question before i will stop bothering you 🙂
    Youtube Settings (Yes i just heard you say urghh)
    Baseing the render on Apple iPod 640 x 480 what settings do i need to change to get 100mb per 10 min and the youtube widescreen size?
    Cheeers Boss!!!!!!
    George
  • John Rofrano
    April 20, 2011 at 8:26 pm
    [George McCreadie] “Baseing the render on Apple iPod 640 x 480 what settings do i need to change to get 100mb per 10 min and the youtube widescreen size?”
    If you want widescreen 16:9 then the dimensions should be set to 640×360. As I said before, use Two Pass and lower the average bit rate to between 1,200,000 and 1,300,000 bps and you should hit your 100mb per 10 minutes.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • George Mccreadie
    April 21, 2011 at 11:07 am
    Thats Great!
    It worked seamlessly.
    Do you know what resoloution i need to get youtube HD?
    -and by doing that will it take longer to render and have a larger file size?
    Thanks John you have been a really big help!
    Is there like a REP button on these forums?
  • John Rofrano
    April 21, 2011 at 12:30 pm
    [George McCreadie] “Do you know what resoloution i need to get youtube HD?”
    YouTube HD can be either 1280×720 or 1920×1080. personally, I feel that 1920×1080 is ridiculous for internet video so I upload all of my HD videos at 1280×720.
    [George McCreadie] “-and by doing that will it take longer to render and have a larger file size?”
    No, the file size is determined by the bit rate. Of course, you should increase the bit rate if you increase your resolution to make sure that you have enough bits to accurately represent the frame.
    [George McCreadie] “Is there like a REP button on these forums?”
    No, but there is a KUDO’s button at the bottom of a post but I’m not sure what it actually does. lol. 😉
    ~jr
  • George Mccreadie
    April 24, 2011 at 11:00 am
    Thanks for the reply john.
    What sort of bit rate would i be looking at or do i need to test it myself.
  • John Rofrano
    April 24, 2011 at 1:27 pm
    [George McCreadie] “What sort of bit rate would i be looking at or do i need to test it myself.”
    That’s the problem. If you want to maintain the same file size you can’t increase the bit-rate. I guess what I’m saying is, forget about HD if you don’t want to increase the file size. I would use at least 2,500,000 – 3,000,000 for 720p HD but that will make your file almost twice as big. (don’t forget HD is 5x the information of SD)
    ~jr
  • George Mccreadie
    April 24, 2011 at 3:15 pm
    Thank You John
Page 2 of 2
