Activity Forums Adobe Media Encoder Unable to get good render quality
  • Unable to get good render quality
    Posted by Giavi Tran on March 22, 2017 at 9:01 pm
    Hello,
    Recently, I have been trying to render out a gameplay video, but I have run into a problem that I just cannot seem to find a solution for. No matter what program(Vegas, Media Encoder, or straight from After Effects) or render setting I use, I encounter the same problem. The quality of the video after every single render degrades horribly, becoming extremely discolored, pixelated, and blurry. I took two screenshots; one of the source material(I know it’s not that good in the first place), and one of the render(Every render ends up looking like this). I have also included a screenshot of the render settings used to achieve the second screenshot’s results, but again, no setting I change seems to yield any different results. I have even tried setting the bitrate to extremely high levels, but even that doesn’t change the outcome of the video render.
    The source material is recorded via Nvidia Shadowplay, and it is 1080p 60 fps MP4.
    My basic PC specs are as follows:
    Windows 64 Bit
    GTX 1080
    i5 6600k
    16 GB of RAM
    2 TB HDD
    Any suggestions are very much appreciated. I would like to find out if it’s an issue with my machine somehow, or just a few settings that need to be tweaked. Thank you.
    Giavi Tran replied 9 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
