Activity Forums VEGAS Pro Unable to find the plugin?
  • Unable to find the plugin?
    Posted by Hsu Chaw-bin on August 19, 2012 at 1:30 am
    So recently I reformatted my system, the old system was Win7 Ultimate 32 bit, I upgraded to 64 bit, I was reinstalling all the plugins I had last night, everything works, except one plugin, Adam’s Flip, after I installed it, I checked Vegas, don’t see Adam’s Flip, I open a project with Adam’s Flip involved:
    ‘An error occurred while loading the project file xxxxx.veg
    An error occurred while loading a plug-in or plug-ins. The plug-in(s) specified are not installed on this system. ‘
    I have no idea why, I even installed at both Program Files directory, but no, it didn’t work.
    I seriously need this plugin, lots of my projects have it involved.
    David Alfredo replied 13 years, 4 months ago 8 Members · 16 Replies
  • 16 Replies
  • Jeff Schroeder
    August 19, 2012 at 3:19 am
    It is probably a 32 bit plugin. Even if you install it in both program files directories a 32 bit plugin will not show up in 64 bit. Use the 32 bit version for projects that require this plugin. You can also use the Pan/Crop tool, just right click the image and choose “Flip Vertical”
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Hsu Chaw-bin
    August 19, 2012 at 4:05 am
    I know, but it’s HIGHLY annoying when you have LOADS of video events to flip.
    Oh well, I’ll go back to 32 bits then
  • Steve Rhoden
    August 19, 2012 at 10:53 am
    Adams flip is a 32bit plugin, so as Jeff said, you wont see
    it. If you are upgrading to a 64bit system, then all
    your software and plugins need to also be 64bit to work
    efficiently and take advantage of the architecture.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Nigel O’neill
    August 19, 2012 at 12:11 pm
    [Hsu Chaw-Bin] “Oh well, I’ll go back to 32 bits then”
    You don’t need to re-install Windows. Just install 32 bit Vegas. Vegas versions happily co-exist.
  • Hsu Chaw-bin
    August 19, 2012 at 12:13 pm
    ….Darn, cause I already re-installed the whole Windows….
    OH WELL, I’ll install back to 64 bit after next time my system break down then.
  • Mike Kujbida
    August 19, 2012 at 12:46 pm
    My new machine at work came with 64 bit Windows.
    I installed both the 32 and 64 bit versions of Vegas as I have a few older plugins that are 32 bit only.
    It’s not a big deal to have to switch back and forth between the two versions.
  • John Rofrano
    August 19, 2012 at 1:07 pm
    [Hsu Chaw-Bin] “….Darn, cause I already re-installed the whole Windows….”
    It’s important for you to understand that there is no reason to ever use the 32-bit version of Windows. The 64-bit version will run everything the 32-bit version will run in compatibility mode.
    Also, it is critically important to all system builders that once you build a new system you preform a full backup and then perform at least weekly incremental backups. Had you created a backup, going back to a 64-bit system would have been as simple as a restore.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    August 19, 2012 at 6:33 pm
    Following the direction of technology, 32bit systems will soon
    be a thing of the past, just like FAT32 and NTFS Drives.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Tim Mccallister
    April 22, 2013 at 7:54 pm
    On two separate 64-bit systems (laptop, desktop), I installed both Vegas11-32 and Vegas11-64. It did not go well. Vegas11-32 wouldn’t boot up, and Vegas11-64 stopped responding.
    Indie Filmmaker
  • David Alfredo
    April 22, 2013 at 7:56 pm
    just by chance… have you updated your system with Windows 7 update KB2670838 ? (Internet Explorer 10 update) if so, uninstall it and hide it from automatic updating before installing Vegas.
