Activity Forums Adobe Premiere Pro Unable to export Quicktime or AVI with timecode
  • Unable to export Quicktime or AVI with timecode
    Posted by Bret Hampton on September 29, 2012 at 1:08 am
    I’m trying to export a movie with my timeline timecode, as the broadcaster requires DF TC, bars and tone, slate, program start at 1:00:00:00 as normally supplied on tape.
    My timeline is set to start at 58:30:00. However no matter which settings I’ve tried, QT, AVI, Match source, etc the finished file always starts at 0. The help menu says timecode data is always exported, even if Metadata settings are all off.
    Appreciate any suggestions.
    Tom Daigon replied 13 years, 12 months ago 3 Members · 5 Replies
  • Chris Tompkins
    September 29, 2012 at 4:35 pm
    So you’re Not laying off to tape then?
    This is a digital file delivery?
    Chris Tompkins
    Video Atlanta LLC
  • Bret Hampton
    September 29, 2012 at 6:03 pm
    Hi Chris
    Yes, it’s for broadcast and I’m required to delivery embedded timecode. I did some tests since I posted and the problem seems to be whenever I use AJA sequence settings. I have Kona LHe card. I’m able to edit to digibeta tape using timeode.
    If I use non-Aja preset for DV the timecode is there. However that’s 720×480 and I don’t want to alter the 720×486 files.
    I also tried Blackmagic presets and they work fine.
    Any ideas?
    Bret
  • Tom Daigon
    September 29, 2012 at 6:06 pm
    FWIW, I have had conversations with tech support about the same issue with my Kona 3. They said PrP does not embed TC in the HD-SDI stream. They said FCP 7 does .
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Bret Hampton
    September 29, 2012 at 6:33 pm
    Tom
    Thanks, that explains the problem. I also have Kona with FCP and no problems there. I guess I’ll have to open the file in FCP and make a new QT with timecode there.
    Really appreciate your help
  • Tom Daigon
    September 29, 2012 at 8:09 pm
    Glad to help, Bret.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
