Activity › Forums › Adobe After Effects › Unable to export more than about 2/3GB
  • Unable to export more than about 2/3GB
    Posted by Charliechap on December 13, 2005 at 12:01 pm
    Hello all,
    I’m having a problem exporting AVI’s and MOV’s on my MAC. When exporting a project it currently is about 10GB, which is a problem in itself but another issue.
    My after Effects doesn’t seem to want to export anymore than about 2/3GB, which means that i then have to send the project in four parts to a DVD authoring house to put together and author onto a DVD.
    My aim is to author at home myself but getting around this exporting in 4 parts would be a good start, can anyone help?
    My computer is a iMac G4, 1.25, 768 RAM, 2 Hard Drives (70GB computer & 200GB external)if that helps.
    Charlie
    Tomogomo replied 20 years, 9 months ago 2 Members · 1 Reply
  • Tomogomo
    December 14, 2005 at 6:29 am
    Hi
    well first of all i would suggest that You export always to frame sequence – ie tga or the like – . Even if Your render fails in the middle You can skip rendered frames and go on . After the render You can import it into any NLE or AE and output it whatever format You like without heart attack when it fail near the end
