Activity Forums Apple Final Cut Pro Legacy Unable to export letterboxed Quicktime
  • Unable to export letterboxed Quicktime
    Posted by Timothy Eaton on May 15, 2007 at 2:23 am
    I’m trying to export an uncompressed NTSC 4:3 letterboxed Quicktime from a DVCPro 720 24p timeline. No luck. I can only get 4:3 cropped, or 4:3 squeezed, but not letterboxed, even though I check preserve aspect ratio using letterbox if necessary. I’ve tried both Export Quicktime Movie with various codecs including Uncompressed, and Quicktime conversion, including Uncompressed. I’m using FCP 10.1.4 on a Dual Quadcore MacPro with Kona LHe. Any ideas? Thanks.
    Timothy Eaton replied 19 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 15, 2007 at 2:25 am
    Nest the sequence in a 4:3 NTSC uncompressed sequence. HD isn’t ever 4:3.. so you need to get it to SD I’d think…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Timothy Eaton
    May 15, 2007 at 7:22 am
    Thanks Jerry. This works! Tim
