Activity Forums Apple Final Cut Pro Legacy unable to export a stereo audio mix
  • unable to export a stereo audio mix
    Posted by Mikhail Goldfarb on January 7, 2009 at 1:12 am
    Hi cutters,
    Well, as usual, making my “final cut” and exporting my Quick Time files, while being suddenly surprized by this. For my first time I see my Audio Mixer with many Master Meters (before I had only seen two ´cause I am not used to go much farther than stereo), and my Channlel (track) faders with the Pan Sliders BLOCKED!!!
    In fact, in spite of all this, INSIDE the FCP the audio sounds stereo. But the resulting Quick Time file from exporting is actually MONO (the LR Meters of my Audio Device Control Pannel jump together in perfect phase and of course, the mono sound is desgusting!
    My other projects work OK… And tomorrow I have to send the job to a client!!
    HELP CUTTERS!!
    Thanx
    Victor Perez replied 17 years, 8 months ago 2 Members · 1 Reply
  • Victor Perez
    January 8, 2009 at 8:21 pm
    Try this,
    Duplicate your sequence to keep the one with the “Many Masters” for later reference between it and the new sequence.
    Right click on the sequence in the Bin and go down to Settings.
    The Sequence Settings window should open.
    Click on the “Audio Outputs” tab on the far right. There you’ll see your outputs from 2 (Stereo) to 24.
    Adjust the grouping to your needs. Stereo lets you pan your audio tracks. Dual Mono does not.
    good luck,
    Victor
