Activity › Forums › Adobe After Effects › Unable to Drag Assets into After Effects CS6
  • Unable to Drag Assets into After Effects CS6
    Posted by Mark Santella on November 4, 2012 at 1:23 pm
    I have looked all around, but I am unable to find a solution to my problem. Any help would be appreciated. I cannot drag any sort of asset into after effects project panel.
    Mark Santella replied 13 years, 10 months ago 2 Members · 2 Replies
  • John Cuevas
    November 4, 2012 at 3:13 pm
    I have this happen to me when my preferences became corrupted, so you might want to try deleting them upon start-up. If you’re on a Mac, hold down the Command + Option + Shift keys as you start After Effects, this will allow you to delete the corrupt preference file. On a PC its Control + Alt + Shift.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Mark Santella
    November 4, 2012 at 4:00 pm
    Thanks John for the suggestion. Unfortunately it did not do the trick. I will keep trying.
