Activity Forums Adobe Premiere Pro Unable to Connect to Capture Driver Message
  • Unable to Connect to Capture Driver Message
    Posted by Elliot Smith on April 6, 2005 at 4:22 am
    When attempting to capture a movie Premiere 6.5 defaults to capture in Microsoft DV on my PC. I want to use Quicktime, but when I go to edit the settings and change the capture format to Quicktime Capture I get the “Unable to Connect to Capture Driver” Message. I would use DV/IEEE 1394 capture, but I went to a workshop the other day (Taught on Macs, I’m on PC) and at the seminar I was told that quicktime captures video uncompressed. I’m trying to improve quality since I saw “digitation” in the highlights of the bride’s forehead at the last wedding I shot on which I used DV to capture.
    Someone suggested I use a video capture card instead of firewire, but I am so far unsatisfied with the results I’ve been getting from the cutrate card. If anyone has any suggestions as to fixing the quicktime or making other adjustments to improve my output, I’d appreciate it.
    Elliot
    Elliot Smith replied 21 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Blast1
    April 6, 2005 at 5:52 am
    [Elliot Smith] “I’m trying to improve quality since I saw “digitation” in the highlights of the bride’s forehead at the last wedding I shot on which I used DV to capture. “
    DV capture is basically transfering DV thats on tape to a computer file with no loss or change, if you captured DV to uncompressedQT you would have uncompressed DV with higher resolution artifacts as any artifacts you are seeing are already on tape.
    Without knowing what causing your pixelation, its hard to recommend any cure, are you viewing the artifacts you are seeing on a computer monitor or a external video monitor? are they in areas of high motion or overexposure?
    are you doing any magnifaction to see them?
  • Scott
    April 6, 2005 at 7:03 am
    Also, was the pixilization on the final DVD? Low bit rate can cause a huge amount of pixelization. If your trying to cram 3 or 4 hours of video on a dvd….
    Scott
  • Steven L. gotz
    April 6, 2005 at 7:00 pm
    The compression happens between the lens and the tape. Too late for uncompressed DV.
    What you may be thinking is that the video is uncompressed on the tape. It is compressed at 5:1 – so as I said. Too late by the time it is on tape.
    A Mac captures DV from a camera the same way a PC does, but names if differently and puts a slightly different wrapper on the file. But the data is a file transfer, so the data is the same on Mac as on PC, from Quicktime MOV to Windows DV – all the same.
    If you want better codecs to work with, you should upgrade your system to Windows XP and get the latest version of Premiere Pro 1.5 – then you will have a better codec (MainConcept) than before. There is a learning curve, but it will be a significant improvement. And the MPEG export is much better in Premiere Pro than in 6.5 as well.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Elliot Smith
    April 7, 2005 at 12:00 am
    Thanks for the advice, I’ll look into Premiere Pro. Thanks again.
  • Elliot Smith
    April 7, 2005 at 12:07 am
    The pixelation was in highlight areas, bright light bouncing off the bride’s forehead. I don’t have an external monitor, but it was there on both computer and DVD.
    I’m beginning to wonder if it was the camera itself, it was a sony trv-130 (far from high end). I used to copy from camcorder to VHS and I never had these issues, but then again that was all analog and the picture is much sharper digitally. Could it be my firewire card?
    I created 2 hour DVD’s, btw.
  • Blast1
    April 7, 2005 at 2:49 am
    [Elliot Smith] “Could it be my firewire card?”
    No, firewire card is strictly a high speed serial port and does not affect the data per’se.
    [Elliot Smith] “I’m beginning to wonder if it was the camera itself, it was a sony trv-130 (far from high end). “
    Actually that series of D8 is a fairly decent camcorder, beats a hi8/8mm, one thing it has is a large imaging chip which lends to low light sensitivity(less noise if set properly) better than some newer model consumer DV camcorders, it has drawbacks though as it has limited manual controls, but it does have a manual exposure and it can be used to tone down highlight problems like you are seeing, its better to slightly underexpose than overexpose, underexposed video can be lightened with minimum loss of detail, overexposure looses detail thats not recoverable, also if possible avoid direct reflection of shiny objects like foreheads, bald heads, it pays to scope out the area and note lighting and possible problems in advance, also play with the cam in various situations to get a feel of what you may need to do it eliminate problems while live shooting, also an item like a Polarizing filter can help a bunch in situations like that, one for a 37mm filter should be very reasonable.
    With your current problem you could try to futz with the adjustments like brightness/contrast, blurs etc. available in AP65 to see if you can clean it up a bit.
  • Elliot Smith
    April 7, 2005 at 5:39 am
    I’ll do that. Thanks alot, you’ve been very helpful.
    Elliot
