Activity Forums Adobe After Effects “Unable to connect to background render”
  • “Unable to connect to background render”
    Posted by Jeremy Sexton on May 11, 2010 at 4:11 pm
    EDIT – I fixed it. I set it to use 7 of 8 processors and it worked no problem. If someone else has this error, there’s your issue.
    Just installed CS5, decided to test the new speed with a little Particular 2 emitter and a light. The RAM preview was FLYING, but when I hit “0” again to stop and play back, I got the error “Unable to connect to background render”.
    Anyone know what this is and what causes it? I have AE set to use 13 of 16 gb of RAM and all 8 processors. Does that have anything to do with it?
    David Biederbeck replied 14 years, 7 months ago 4 Members · 4 Replies
  • Elias Huch
    July 7, 2011 at 5:27 pm
    Jeremy,
    Not sure what you mean by fixed it, but I’m having the same issue. However, I am using the new 12 core Mac Pro with 26 Gigs of RAM. It flies through the ram preview, but as soon as it is ready to play I get the error “Unable to connect to background render” in the info panel. Any thoughts?
    Eli
    Elias Huch
    Motion Graphics Designer
    Reelvizion Productions
  • Jeremy Sexton
    July 7, 2011 at 5:34 pm
    I set After Effects to use only 7 of my 8 cores and never had this issue again.
    Try setting it to use 10 or 11 of yours and see if that helps.
  • Raine Vivian
    September 6, 2011 at 2:50 pm
    I was having that problem as well. Have a quad core and Have 3 cores set to after effects, 8 gigs of ram. Changed the “RAM all location per background CPU” from 1, to 2 and it helped.
    -Raine Vivian
    http://www.rainevivian.net
    http://www.seaboundesign.com
  • David Biederbeck
    February 12, 2012 at 5:18 am
    Even 7 of 8 seems a bit low. I find the best results come from 6 of 8 on my machine and only 22 ram of 32.
