Activity Forums Storage & Archiving Unable to change Raid mode on RocketRaid 4322
  • Unable to change Raid mode on RocketRaid 4322
    Posted by Vicente Perez on September 29, 2015 at 4:45 am
    Hi! I have a RocketRaid 4322 (not my choice, it came with the system) and I am unable to access the settings through HighPoint’s WebGUI. I know I have been able to do it in the past, but it no longer seems to work.
    The raid is running great, though. It mounts right away, but I wanted to change it from 5 to 0. Unfortunately, I am stuck, since I cannot access the settings.
    I contacted HighPoint, but they said that the product has been discontinued and I am on my own.
    Any suggestions? Is there a way to change the raid level without the WebGUI? Perhaps I have to find a legacy version of the WebGUI?
    Running OSX 10.10.5 on a 2009 Mac Pro.
    Vicente Perez replied 10 years, 11 months ago 2 Members · 4 Replies
  • Bob Zelin
    September 30, 2015 at 4:01 pm
    to change any raid from one level to another, you have to blow away all the media, and start from scratch (delete the raid group).
    So are you saying that you have deleted the raid 5 group, and you are starting from scratch, and raid 0 is not a choice in your GUI ?
    You do realize that if you lose one drive in a RAID 0 group, you lose all your data – correct ?
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Vicente Perez
    September 30, 2015 at 6:39 pm
    Thank you for your response. Yes, I know that I have to lose all the data to change levels. I have already backed it up. The issue is that, although the raid mounts and I can see if I go to disc utility, it does not show up through HighPoint’s GUI. It is not that it does not give me the option to change leves, it is that I don’t see the raid at all. I have asked HighPoint, but they say that the RR4322 is discontinued and no longer supported.
    I assume that I can reinitialize the raid from disc utility, but that won’t help with changing the level. I have to change to 0 in order to use the full capacity of the drives, and I no longer need redundancy.
    Hope this clarifies. Thanks!
  • Bob Zelin
    October 1, 2015 at 1:32 pm
    if you email me, I would be more than happy to take a look at this for you for free.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Vicente Perez
    October 6, 2015 at 7:34 pm
    So, in case this helps anybody further down the road (I don’t have access to a PC, so not much I can do), from HighPoint:
    RR4322 has no SW support for OS X 10.10 or later.
    If you need to use the RAID management, you may try to use the out-of-band RAID management through the Ethernet port of RR4322. You may need to setup a IP address in the RR4322’s FW under a PC system.
