Activity › Forums › Apple Final Cut Pro Legacy › Unable to change font type in text controls
Posted by Teerav on July 24, 2006 at 7:24 pmanybody have any idea why this is? its starting to get extremely frustrating,
Teerav replied 20 years, 2 months ago 3 Members · 9 Replies -
Kevin Monahan
July 24, 2006 at 7:36 pmDon’t use the standard text generator. Try Boris Title 3D instead. It’s in your Generators menu. Problems with Boris? Repost.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Teerav
July 24, 2006 at 7:47 pmthanks, im aware of boris’s title 3d, but it hasnt really impressed me too much. id like to be able to use the basic text for simple things like a slate and whatever else.
David Roth weiss
July 24, 2006 at 7:55 pmAs Kevin says Boris 3D really is the one to use. My guess is that you may not be using it correctly. Take a few minutes to read the online help, as it is vastly superior and actually much easier than the basic text generator. BTW, some fonts are simply not available to the text generators and they will not change when you attempt to do so.
DRW
Kevin Monahan
July 24, 2006 at 8:19 pmRegular text generators are dead to man, DEAD. 😉 Haven’t used ’em since FCP 2.
Regardless of how krappy they are, and how much you really should avoid them nowadays they should still work for down and dirty junk.
“When animals attack”….trash yer prefs then post back.
Kevin Monahan
fcpworld.com
Pres. SF Cutters -
Teerav
July 24, 2006 at 9:32 pmits irritating clicking on a drop down menu and having nothing drop down, and as i’d hate to continue the controversey, but if i need good looking text, i believe it does not lie within boris or even FCP for that matter. having no Z axis and limited lighting effects does not allow for too much creative text designing in my opinion. but hey, to each their own. thanks for the help guys
Kevin Monahan
July 24, 2006 at 10:26 pmIf no fonts show up, it’s pointing to a corruption of some kind. Again, trash your prefs and let us know if your fonts return. Let us know.
Kevin Monahan
fcpworld.com
Pres. SF Cutters -
Teerav
July 25, 2006 at 12:31 ami trashed using FCP Rescue 5. still unable to access any font, any other ideas?
Kevin Monahan
July 25, 2006 at 1:47 amDid you see if any of your other apps are having this issue with your fonts?
I’d check that out.If everything else seems good, you might try the following in order and one at a time:
Repair Disk Permissions with Disk Utilities
Rebuild your directory with Disk Warrior
Reinstall FCP
Do a “Clean” Re-install of OS XIf all else fails:
Do a full erase and install of OS X
Reinstall FCPKevin Monahan
fcpworld.com
Pres. SF Cutters -
Teerav
July 25, 2006 at 8:25 pmlol, ok well i feel slightly stupid. But at least i figured out why it was doing that. from the right, i have my cinema display, another 17″ next to it, then my ntsc monitor (through blackmagic card). i use the far left side of the 17″ for the viewer and right next to it for the canvas, and the cinema display for everything else. well i guess because the viewer is right next to the ntsc monitor, when i drop down the font menu, it drops down, but on the ntsc monitor right next to it. but because the monitor is displaying the preview, the font list shows up behind it. guess i need to to some window rearranging. thanks for the help
