Activity Forums Apple Final Cut Pro Legacy Unable to capture timecode via Firewire
  • Unable to capture timecode via Firewire
    Posted by Duncan Hill on March 16, 2010 at 3:05 pm
    I am captureing HDV footage from a Z1 camera via a firewire to FCP on a mac book pro.
    I am capturing the footage using a HDV 1080i50 sequence setting and the apple intermediate codec. All is fine up to this point.
    Once I capture the footage, each clip I capture, the timecode begins at 00:00:00:00, even though the time code on the tape says completely differently (I have shot each reel starting with a different number ie 01:00:00:00, 02:00:00:00 etc).
    Do I need a special firewire cable to transfer HDV material? (is there too much information for my standard firewire cable to cope with?) or is there a simple setting in FCP that I’m missing?
    Any help is much appreciated.
    Also, I can’t use log an capture in HDV mode, I can’t assign tape numbers etc, when i hit log and capture it just automatically captures the footsge without me controlling the deck and assigning tape numbers as i would in SD.
    thanks again for any help…
    Tom Wolsky replied 16 years, 6 months ago 3 Members · 9 Replies
  • 9 Replies
  • Tom Wolsky
    March 16, 2010 at 4:15 pm
    If you transcode to AIC the timecode is lost. You only retain timecode if you capture native HDV.
    There is no logging function if you transcode to AIC, only with native HDV capture.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Duncan Hill
    March 16, 2010 at 4:42 pm
    Thank you for enlightning me Tom. I must say, what a terrible feature, what is that point in that?
    Next problem…When I try to capture native HD, my FCP crashes completely with an error sayng FCP quit unexpectedly. Any ideas on how I might be able to fix this problem? I am using FCP version 5.
    Thanks again!
  • Tom Wolsky
    March 16, 2010 at 4:48 pm
    Trash your preferences.
    Please give your full system specifications, what computer, what drives, what camera or deck, how everything’s connected, what settings are on the media, what settings you’re using in Final Cut, and finally what version of the software, of the OS, and of QuickTime you are using.
    All the best,
    Tom
  • David Roth weiss
    March 16, 2010 at 5:04 pm
    Duncan,
    AIC is essentially a dead “legacy” codec that should no longer be used. It was designed years ago when HDV was first came out and there was no native HDV editing. Today, we capture and edit HDV either as native HDV or ProRes. Both techniques capture timecode off the tape.
    If you wish to capture HDV as ProRes on the fly via firewire, read the following tutorial: https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Duncan Hill
    March 16, 2010 at 5:23 pm
    okay:
    FCP: Version 5.0.4
    Computer: Mac Book Pro, Mac OSX 10.5.8
    System Spec: 2.93 GHz Intel Core 2 Duo, 4 Gig Memory 1067 MHz DDR3
    Drives: Capturing to 250gig Internal Hard Drive
    Camera: Sony Z1
    Connections: Firewire cable (400) from Z1 to Mac Book Pro
    FCP Settings: Sequence Settings – 1080i50, Capture Preset – HDV, Device Control – HDV Firewire
    Quicktime: Version 7.6.4
    thanks again for your time Tom. much obliged
  • Tom Wolsky
    March 16, 2010 at 5:53 pm
    After you trashed your preferences what happened? How much space left on the internal drive?
    All the best,
    Tom
  • Duncan Hill
    March 16, 2010 at 7:28 pm
    sorry Tom, I’m a bit of an FCP novive. how do I trash my preferences?
  • Duncan Hill
    March 16, 2010 at 7:32 pm
    thanks for the update David. I think the link you sent me, as good as it is, is for a later version of FCP, I have version 5 and can’t find anything regarding a Pro res setting…
  • Tom Wolsky
    March 16, 2010 at 8:30 pm
    https://www.fcpbook.com/Misc1.html
    All the best,
    Tom
