Activity Forums VEGAS Pro Unable to burn iso image ?
  • Unable to burn iso image ?
    Posted by Rick Hughes on December 26, 2015 at 1:43 pm
    Using DVDA 5
    Menus etc all created fine …… run the ‘make DVD‘ wizard and the ‘prepare‘ option.
    This all completed as usual and no errors (folder contains usual structure of files)… but when I went to next step of ‘make DVD‘ and ‘burn‘ previously prepared project … I can select the project. – OK
    I can Select ISO writer from drop down list of devices and the directory to put file in ……..
    But I do not get the option to proceed ? the Next button is greyed out.
    Only this different is that I selected option for DVD 8.5GB rather than the usual 4.7 …. but would have thought it should still be able to create an ISO file ?
    Picture of the ‘make DVD‘ screen:
    Rick Hughes replied 10 years, 9 months ago 2 Members · 2 Replies
  • Jorma Nippala
    December 26, 2015 at 5:14 pm
    Try toggling the “Use legacy disc drivers” option in Options > Preferences > Burning. This option is in the later builds of DVD A Studio 5.
    Remember of course that the ISO Image Writer is a software “device” that you “burn” to like you would for a hardware device. No physical disc is burnt, only an ISO file is created.
  • Rick Hughes
    December 26, 2015 at 7:31 pm
    Didn’t work.
    I did a de-install and re-install and it is now OK …. must have become screwed up
