Activity › Forums › Adobe Illustrator › un-unlockable illustrator objects?
  • un-unlockable illustrator objects?
    Posted by Wade Stubanas on September 17, 2012 at 7:21 pm
    I am working on a periodic table (received from a client).
    I have unlocked everything on the document, however the element boxes are still locked and unmovable, editable, etc.
    I can select the Li, Be, 004, and element names, but not the boxes. What is going on here?
    Wade Stubanas replied 14 years ago 3 Members · 4 Replies
  • Vincent Rosati
    September 18, 2012 at 12:41 am
    Verify that everything is unlocked..
    mac opt + cmd + 2
    pc ctrl + alt + 2 (i think)
    Any chance you can attach the file?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Wade Stubanas
    September 18, 2012 at 1:01 am
    Vincent,
    Here is the file.
    4672_periodictablebrochure9172012.ai.zip
    not sure hot to PM you the PW, so whatever, its 4809.
    Thanks for taking a look!
  • David Cabestany
    September 18, 2012 at 12:07 pm
    They are in a separate locked layer.
    Go to the layers panel and click the lock icon.
  • Wade Stubanas
    September 18, 2012 at 3:35 pm
    That is it! Thank you!
