Activity › Forums › Adobe After Effects › UN trim comp to work area
Posted by Andy Acourt on May 19, 2008 at 12:57 pmHi
I’ve just trimmed my comp to work area and lost the first 3/4 of comp.
Can I get it back?
thanks
John Nelson replied 6 years, 9 months ago 5 Members · 6 Replies -
Jeremy Fabiano
May 19, 2008 at 8:24 pmDid you do anything after it?…
CTRL + Z = UNDO (edit menu -> undo)
if you closed it already tho…. g’luck remembering how you made it – i don’t recall there being a way of getting it back..
-Jeremy
Andy Acourt
May 19, 2008 at 8:57 pmthanks for that.
I found a way in the end
Go to comp settings and reset the time back to original values. THen select all layers and drag them back into the time line.
Chuose Osemeka
August 20, 2017 at 1:52 amMister you saved me a whole lot of hassle.
thanks it worked.???? -
John Nelson
November 21, 2019 at 3:20 amYet another AE wannabe!
After watching a video on stabilizing my UNstable footage the tutor said to “trim comp to work area”. Then, after doing that I sat scratching my head, wondering HOW to UN trim the comp…
Your suggestion also ‘saved my bacon’ on the project.
KEEP ON KEEPIN ON!
