Activity Forums VEGAS Pro un-syncing the audio and video
  • un-syncing the audio and video
    Posted by Paul Dana on December 11, 2007 at 10:16 pm
    To make a slide show, I dropped some .jpgs in the video line and an .mp3 on the voice line. When I try to move or edit the music, it moves portions of the video (undesirably!). Is there a way to move the items on each editing line without affecting other editing lines?
    Paul Dana replied 18 years, 8 months ago 2 Members · 4 Replies
  • Edward Troxel
    December 11, 2007 at 10:21 pm
    Select the piece you want to move and press “U” to “ungroup” them. Alternately, you can turn on “Ignore Event Grouping” but you have to remember to turn it back off!
    Edward Troxel
    JETDV Scripts
  • Paul Dana
    December 11, 2007 at 11:13 pm
    So sorry… but toggling “ignore event grouping” has no effect (..tried that before my post!). Using “alt”, “ctrl+alt”, and “ctrl” allow me to move music within the envelope, but as soon as I try to resize the music, it affects the video portion. In fact, it splits the video at seemingly random portions of the slide show unless I try to resize it at the very beginning, which always moves the entire video and audio. If I try to resize the audio at the very end, it selects one of the pictures in the video at random and overlaps all of the rest of them.
    I finally resolved the problem by moving the audio within the envelope using “ctrl+alt”, then splitting the audio using “s” at the end of the clip and deleting the unwanted portion of the audio created by the split, but there has to be a better way! The beginning of the clip is still only marginally acceptable!
    Any suggestions are greatly appreciated. Thanks in advance!.. Paul
  • Edward Troxel
    December 12, 2007 at 2:40 pm
    Ok, here’s what might be going on. Try turning OFF “auto ripple”
    Edward Troxel
    JETDV Scripts
  • Paul Dana
    December 13, 2007 at 6:35 pm
    That worked. Thank you!!!!
