Activity Forums Adobe After Effects un-stabilize/offset anchor point keyframes
  • un-stabilize/offset anchor point keyframes
    Posted by Hellfritsch on March 15, 2007 at 5:39 am
    I’ve stabilized a shot to make rotoscoping easier. I precomposed & keyframed my masks. Now I want to “undo” the stabilize…
    I’m assuming i need to use expressions to interpret anchor point data but I have no experience with expressions.
    all help is greatly appreciated!
    Peter O’connell replied 19 years, 6 months ago 3 Members · 3 Replies
  • Hellfritsch
    March 15, 2007 at 5:10 pm
    if i delete my anchor point keyframes all my roto masks will be off. i need to somehow re-apply motion to the nested/precomposed comp that is based on the stabilize data. here’s the layout:
    stabilized footage in comp A > nest comp A in comp B & animate masks > nest comp B in comp C and (somehow) un-stabilize
  • Robert Houghton
    March 15, 2007 at 11:24 pm
    Alright, I got it to work with some footage I have on the system. This is how I did it:
    Comp A: Stabilized Footage
    Comp B: Rotoscoping from stabilized footage
    Comp C: Original Footage + Comp B (Precomped of course).
    All I had to do is copy the anchor point keyframes of the stabilized footage to Comp B’s position data in Comp C. The mask lined up precisely with the tracking data. Give ‘er a shot.
    -Rob
    Motion Graphics Animation
    Professional & Freelance
    Respond2
    Opinions expressed above are not in any way connected to Respond2.
    Personal website under construction 😉
  • Peter O’connell
    March 16, 2007 at 12:20 am
    anchor point = position
    is the basic expression you are looking for.
    Good luck
    Pete O’Connell
    http://www.barxseven.com
