Activity › Forums › Panasonic Cameras › Un-Squeezed Video?
  • Noah Kadner
    April 10, 2006 at 11:55 pm
    Yes- if you are in FCP you load it into a 4:3 sequence and then use the aspect ratio/distort controls in the motion tab of the clip. It will take a while to render though.
    Noah
  • Ken Pugh
    April 23, 2006 at 12:10 pm
    It’s all real time on my system, which is not especially up to date (Dual G4125). Not even a green line (preview mode). I find the best way is to zoom by 133.33 then adjust aspect ratio to -33.33 (if this does not work post back and I’ll check – I’m away from the edit system at the moment).
    Best,
    Ken.
